Fail to restore grafana.db backup
I am trying to restore a backup of the grafana database along with the corresponding grafana.ini
These backups were made in different versions of Grafana
Grafana Version Old: 8.5.2
Grafana Version New: 8.5.5
In the logs you can see that the connection is stuck in “lvl=info msg=“Connecting to DB” dbtype=sqlite3”
I’m not sure but it may be sqlite3 credential issue? This grafana server is almost by default, the only change is the user admin password and the default home page, and 700 handmade dashboards from different databases
I also tried 2 different backups, but I have the same problem
attached logs
logger=settings t=2022-06-10T21:22:01.56+0000 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2022-06-10T21:22:01.56+0000 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2022-06-10T21:22:01.56+0000 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2022-06-10T21:22:01.56+0000 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2022-06-10T21:22:01.56+0000 lvl=info msg="App mode production"
logger=sqlstore t=2022-06-10T21:22:01.56+0000 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2022-06-10T21:22:01.85+0000 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T18:50:28Z
logger=settings t=2022-06-10T21:22:01.85+0000 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2022-06-10T21:22:01.85+0000 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2022-06-10T21:22:01.85+0000 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2022-06-10T21:22:01.85+0000 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2022-06-10T21:22:01.85+0000 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2022-06-10T21:22:01.85+0000 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2022-06-10T21:22:01.85+0000 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2022-06-10T21:22:01.85+0000 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2022-06-10T21:22:01.85+0000 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2022-06-10T21:22:01.85+0000 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2022-06-10T21:22:01.85+0000 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2022-06-10T21:22:01.85+0000 lvl=info msg="App mode production"
logger=sqlstore t=2022-06-10T21:22:01.85+0000 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2022-06-10T21:22:02.28+0000 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T18:50:28Z
logger=settings t=2022-06-10T21:22:02.28+0000 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2022-06-10T21:22:02.28+0000 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2022-06-10T21:22:02.28+0000 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2022-06-10T21:22:02.28+0000 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2022-06-10T21:22:02.28+0000 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2022-06-10T21:22:02.28+0000 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2022-06-10T21:22:02.28+0000 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2022-06-10T21:22:02.28+0000 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2022-06-10T21:22:02.28+0000 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2022-06-10T21:22:02.28+0000 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2022-06-10T21:22:02.28+0000 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2022-06-10T21:22:02.28+0000 lvl=info msg="App mode production"
logger=sqlstore t=2022-06-10T21:22:02.28+0000 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2022-06-10T21:22:02.51+0000 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T18:50:28Z
logger=settings t=2022-06-10T21:22:02.51+0000 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2022-06-10T21:22:02.51+0000 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2022-06-10T21:22:02.51+0000 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2022-06-10T21:22:02.51+0000 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2022-06-10T21:22:02.51+0000 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2022-06-10T21:22:02.51+0000 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2022-06-10T21:22:02.51+0000 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2022-06-10T21:22:02.51+0000 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2022-06-10T21:22:02.51+0000 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2022-06-10T21:22:02.51+0000 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2022-06-10T21:22:02.51+0000 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2022-06-10T21:22:02.51+0000 lvl=info msg="App mode production"
logger=sqlstore t=2022-06-10T21:22:02.51+0000 lvl=info msg="Connecting to DB" dbtype=sqlite3
logger=settings t=2022-06-10T21:22:02.79+0000 lvl=info msg="Starting Grafana" version=8.5.5 commit=d32ae1890 branch=HEAD compiled=2022-06-06T18:50:28Z
logger=settings t=2022-06-10T21:22:02.79+0000 lvl=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2022-06-10T21:22:02.79+0000 lvl=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2022-06-10T21:22:02.79+0000 lvl=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2022-06-10T21:22:02.79+0000 lvl=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2022-06-10T21:22:02.79+0000 lvl=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2022-06-10T21:22:02.79+0000 lvl=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2022-06-10T21:22:02.79+0000 lvl=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2022-06-10T21:22:02.79+0000 lvl=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2022-06-10T21:22:02.79+0000 lvl=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2022-06-10T21:22:02.79+0000 lvl=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2022-06-10T21:22:02.79+0000 lvl=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2022-06-10T21:22:02.79+0000 lvl=info msg="App mode production"
logger=sqlstore t=2022-06-10T21:22:02.79+0000 lvl=info msg="Connecting to DB" dbtype=sqlite3
Using Grafana 8.4.8 version solve the problem
