Is there a way to extrract out a value from an object in grafana e.g the first in the array for example
The closest I can find for testing is this
How do I get the first in the tags array out for graphing/plotting or tabling. In my case I want to plot max value of the rssi value in the json object above.
8.0.6 -
extract an object from a json objec for plotting -
I wonder can I use the script(under options to do this) here?
What happened?
na -
as above -
na -
na -
no
