Hello
I use Grafana 10.2.2
I am trying to extract a value from a JSON object
I have something like that :
"_id": "epB66o0BZ5Ji4NATaI-2",
"_index": "maas_prd-whiteapp-000003",
"_type": "_doc",
"correlation_id": "c1f95859-a1d9-46a1-a08a-96c5e6dfe8e9",
"description": "",
"details": {
"task_params": {
"args": "['e2d8d1ca-803b-4058-b290-42f0fb5870f0', 'backend_log', 'bbox_202402271200_1']",
"kwargs": "{'correlation_id': 'c1f95859-a1d9-46a1-a08a-96c5e6dfe8e9'}"
"task_state": "SUCCESS"
"timestamp": [ "2024-02-27T12:11:33.087Z" ]
When i use the tranformation " Extract fields" with this
path : details.task_params.args[2]
I get only one char “e” !! it’s the third letter
how can i do to get the third field : bbox_202402271200_1
Thanks
regards
DMA
