Grafana v10.2.2 on Linux -
I have an array of data (a current trace) that I’m injecting into an InfluxDB instance as a string and then applying some data manipulation to in order to recover the array. I’d like to take this array of data and plot it using the Plotly visualization plugin and have this update every so often when new data comes in. -
I’m currently reading in the data from InfluxDB as
import "array"
import "strings"
from(bucket: "MyBucket")
|> range(start: -1h)
|> filter(fn: (r) => r._measurement == "MyMeasurement" and r.sensor == "trace")
|> map(fn: (r) => ({r with _value: strings.split(t: " ", v: strings.substring(start: 1, end: 3072, v: r._value))}))
|> last()
|> yield()
but not sure what this data output looks like and how to now use it for plotting in Grafana
What happened?
I get an error with this query sayinginvalid: runtime error @7:6-7:118: map: map object property "_value" is array type which is not supported in a flux table
I’d like the data to be in a format I can use with Plotly. -
I’ve followed along with here, here and others but I’m not too familiar with how to massage the query output for use with Plotly.
