I’m trying to find a way for the following problem: we want to measure the CPU usage (%) per instance, therefore we’re using the following query:
100 - (avg by (instance) (irate(node_cpu_seconds_total{instance=~"$instance",job="<our_job>",mode="idle"}[1m])) * 100)
We also have defined a variable (query type) for selecting which instance we want to query:
label_values(instance)
(this variable has support for ‘Multi-value’)
What we can’t achieve though is: when we select more than one instance, the graph is created only for the last instance - we’d like to have different lines for each instance.
Graph for 2 instances
Graph for the last instance
Is there a way for doing this? Thanks!
