Hey there,
I am fairly new to grafana and just found something where google couldn’t provide me an outright answer. Probably there is something obvious that I am missing or not understanding right now and hope anyone here can help me with - even if it is just by naming my problem.
v8.4.1 (53f5c6a44c) on Kubernetes from kube-prometheus.
Data source is prometheus -
I am would like to express a relationship between a current value and the maximum possible value to establish the “usage”.
Ultimately, I would like to express this in absolute numbers and relative numbers (%).
To be specific, I would like to set the sum of all k8s pod reservations per k8s node in relationship to the maximum available resources.
So for instance the panel should show something like 1.09 CPU requested of 2 CPU maximum
→ (100/2)*1.09 = 54,5% used
This could be a gauge, a bar or whatever works in the end.
- How are you trying to achieve it?
The current value is represented by the query
(sum(kube_pod_container_resource_requests{resource="cpu"}) by (node))
The maximum value is
kube_node_status_allocatable{resource="cpu"}
Both work as individual queries as shown in the screenshot:
- What happened?
Summarising an answer to both questions:
When I try to do query with both individual metrics I got “no data”, like:
(100 / kube_node_status_allocatable{resource="cpu"}) * (sum(kube_pod_container_resource_requests{resource="cpu"}) by (node))
(100 / kube_node_status_allocatable{resource="cpu"}) * (sum(kube_pod_container_resource_requests{resource="cpu"}))
I guess the issue is the mapping between the two queries but I have no idea how to solve it.
An alternative for me would be to use
as the graph (e.g. GAUGE) value and reference
as the maximum value - but I have no idea how to do that either and my google fu is failing, too.
I also tried to a math expression like
$B -$A
but I am getting a lot more graphs than I expected…
No errors except “no data” found. -
I am not sure what to look for, hence I have no instructions
TY,
Dominik
