/etc/grafana/grafana.ini ignored
Hello
I’m new to Grafana. I have a Debian 10 VM and I installed Grafana from APT repo. I have a simple problem.
/etc/grafana/grafana.ini is just… ignored.
The first try was about changing sqlite3 to mysql (mariadb). I saw it was not working so I tried something simple, changing:
The http port to use
;http_port = 3000
to
;http_port = 3250
But the web server still respond to port 3000 and socket is binded to it
mag 28 13:20:29 maz-v267-test grafana-server[3404]: t=2020-05-28T13:20:29+0200 lvl=info msg=“HTTP Server Listen” logger=http.server address=[::]:3000 protocol=http subUrl= socket=
Then i moved /etc/grafana/grafana.ini to /etc/grafana/grafana.bak, leaving no grafana.ini behind… process fails upon restart. so It’s not completely “ignored” but what’s inside is not effective.
Can you help me?? thanks!
Lines starting with semi-colon ; are comments (and the default value) and are not being read by Grafana.
If you want to change any settings you need to delete the semi-colon.
Semi-colon means “comment” (in other words, ignore).
Remove the semi-colon so that the line reads purely “http_port = 3250” and
then restart Grafana.
Antony.
Why the heck is a ‘;’ used as a comment when a ‘#’ is used all over .ini file? :exploding_head:
All?
A line with contiguous trailing whitespace followed by a semicolon (;, ASCII 0x3E) indicates a comment. Some INI dialects furthermore allow use of the number sign (#, ASCII 0x23) to denote a comment, mirroring Unix shell comments.
