Error updating Grafana Tempo version 2.2.3 to 2.6.1
I have a containerized observability stack on EKS, with Grafana, Loki, Tempo, and Prometheus. When upgrading Tempo from 2.3 to 2.6.1, the Tempo pods upload without issues, but the tempo-query-frontend pod only uploads the tempo-query container; only the query-frontend pod. Therefore, the pod crashes in CrashLoopBackOff (1/2).
I thought the error was associated with the storage block version, because Tempo 2.2.3 used vParquet, and according to the documentation, Tempo 2.6 and later uses vParquet4. However, this did not resolve the following error:
flag provided but not defined: -http.base-path
Usage of /tempo-query:
-config string
A path to the plugin’s configuration file
NOTE: It’s important to mention that I also updated the flag value from <query.base-path> to <http.base-path>, and after this change, we still see the message that this value is not defined.
ExampleManifetsTEMPO:
apiVersion: v1
kind: ConfigMap
metadata:
namespace: {{ .Values.global.namespace }}
labels:
app.kubernetes.io/name: tempo
app.kubernetes.io/instance: tempo
app.kubernetes.io/version: “2.0.1”
data:
tempo-query.yaml: |
backend: 127.0.0.1:3100
overrides.yaml: |
  overrides: {}
tempo.yaml: |
  compactor:
    compaction:
      block_retention: {{ .Values.global.tracing.retention }}
      compacted_block_retention: 30m
      compaction_cycle: 30s
      compaction_window: 30m
      max_block_bytes: 107374182400
      max_compaction_objects: 6000000
      max_time_per_tenant: 5m
      retention_concurrency: 10
      # v2_in_buffer_bytes: 5242880
      # v2_out_buffer_bytes: 20971520
      # v2_prefetch_traces_count: 1000
    ring:
      kvstore:
        store: memberlist
  distributor:
    receivers:
      otlp:
        protocols:
          http:
            endpoint: 0.0.0.0:55681
          grpc:
            endpoint: 0.0.0.0:4317
    ring:
      kvstore:
        store: memberlist
  ingester:
    lifecycler:
      ring:
        kvstore:
          store: memberlist
        replication_factor: 3
      tokens_file_path: /var/tempo/tokens.json
    complete_block_timeout: 30m
  memberlist:
    abort_if_cluster_join_fails: false
    join_members:
    - tempo-gossip-ring
  multitenancy_enabled: false
  overrides:
    metrics_generator_processors:
    - service-graphs
    - span-metrics
    per_tenant_override_config: /conf/overrides.yaml
    max_bytes_per_trace: 10000000
    max_bytes_per_tag_values_query: 10000000
  querier:
    frontend_worker:
      frontend_address: tempo-query-frontend-discovery.{{  .Values.global.namespace }}.svc.cluster.local:9095
    max_concurrent_queries: 50
    search:
      external_endpoints: []
      external_hedge_requests_at: 8s
      external_hedge_requests_up_to: 2
      prefer_self: 10
      query_timeout: 30s
    trace_by_id:
      query_timeout: 10s
  query_frontend:
    max_retries: 2
    search:
      concurrent_jobs: 1000
      target_bytes_per_job: 104857600
    trace_by_id:
      query_shards: 50
  server:
    grpc_server_max_recv_msg_size: 8e+06
    grpc_server_max_send_msg_size: 8e+06
    http_listen_port: 3100
    http_server_read_timeout: 30s
    http_server_write_timeout: 30s
    log_format: logfmt
    log_level: info
  storage:
    trace:
      backend: s3
      s3:
        bucket: {{ .Values.global.tracing.bucket }}-{{ .Values.global.monitoring.clusterName }}
        endpoint: s3.us-east-1.amazonaws.com
        insecure: true
      block:
        version: vParquet4
      blocklist_poll: 10m
      blocklist_poll_tenant_index_builders: 3
      cache: memcached
      memcached:
        consistent_hash: true
        host: tempo-memcached
        service: memcached-client
        timeout: 500ms
      wal:
        path: /var/tempo/wal
  usage_report:
    reporting_enabled: true
#Services
apiVersion: v1
kind: Service
metadata:
labels:
app.kubernetes.io/component: compactor
spec:
type: ClusterIP
ports:
- name: http-metrics
port: 3100
targetPort: http
protocol: TCP
selector:
apiVersion: v1
kind: Service
metadata:
labels:
app.kubernetes.io/component: distributor
spec:
type: ClusterIP
ports:
port: 3100
protocol: TCP
targetPort: http
- name: grpc
port: 9095
appProtocol: tcp
targetPort: 9095
- name: distributor-otlp-http
port: 55681
protocol: TCP
targetPort: otlp-http
- name: distributor-otlp-grpc
port: 4317
appProtocol: tcp
targetPort: otlp-grpc
- name: distributor-otlp-legacy
port: 55680
appProtocol: tcp
selector:
apiVersion: v1
kind: Service
metadata:
labels:
spec:
type: ClusterIP
ports:
port: 3100
protocol: TCP
targetPort: http-metrics
port: 55681
protocol: TCP
selector:
apiVersion: v1
kind: Service
metadata:
labels:
app.kubernetes.io/component: ingester
spec:
ports:
port: 3100
protocol: TCP
targetPort: 3100
- name: grpc
port: 9095
appProtocol: tcp
targetPort: 9095
selector:
apiVersion: v1
kind: Service
metadata:
labels:
spec:
ports:
port: 3100
protocol: TCP
targetPort: 3100
- name: grpc
port: 9095
appProtocol: tcp
targetPort: 9095
selector:
apiVersion: v1
kind: Service
metadata:
labels:
app.kubernetes.io/component: memcached
spec:
ports:
- name: memcached-client
port: 11211
protocol: TCP
targetPort: 11211
port: 9150
protocol: TCP
selector:
apiVersion: v1
kind: Service
metadata:
labels:
app.kubernetes.io/component: querier
spec:
ports:
port: 3100
protocol: TCP
targetPort: 3100
- name: grpc
port: 9095
appProtocol: tcp
targetPort: 9095
selector:
apiVersion: v1
kind: Service
metadata:
labels:
app.kubernetes.io/component: query-frontend
spec:
type: ClusterIP
ports:
port: 3100
protocol: TCP
targetPort: 3100
- name: grpc
port: 9095
appProtocol: tcp
targetPort: 9095
- name: tempo-query-jaeger-ui
port: 16686
targetPort: 16686
- name: tempo-query-jaeger-grpc
port: 16685
targetPort: 16685
appProtocol: tcp
- name: tempo-query-metrics
port: 16687
targetPort: jaeger-metrics
publishNotReadyAddresses: true
selector:
apiVersion: v1
kind: Service
metadata:
labels:
spec:
type: ClusterIP
clusterIP: None
ports:
- name: http
port: 3100
protocol: TCP
targetPort: 3100
- name: grpc
port: 9095
appProtocol: tcp
targetPort: 9095
- name: grpclb
port: 9096
appProtocol: tcp
targetPort: grpc
port: 16686
targetPort: 16686
port: 16685
targetPort: 16685
appProtocol: tcp
port: 16687
selector:
apiVersion: v1
kind: Service
metadata:
labels:
app.kubernetes.io/component: gossip-ring
spec:
type: ClusterIP
clusterIP: None
ports:
- name: gossip-ring
port: 7946
protocol: TCP
targetPort: http-memberlist
selector:
app.kubernetes.io/part-of: memberlist
#Deployments-StatefulSet
apiVersion: apps/v1
kind: Deployment
metadata:
labels:
annotations:
configmap.reloader.stakater.com/reload: “tempo-config”
spec:
minReadySeconds: 10
progressDeadlineSeconds: 600
replicas: 1
renamespaceHistoryLimit: 10
selector:
matchLabels:
strategy:
rollingUpdate:
maxSurge: 0
maxUnavailable: 1
template:
metadata:
labels:
annotations:
fluentbit.io/exclude: “true”
spec:
serviceAccountName: {{ .Values.global.monitoring.servicesAccount }}
containers:
- args:
- -target=compactor
- -config.file=/conf/tempo.yaml
- -mem-ballast-size-mbs=1024
image: grafana-tempo-2.6.1
imagePullPolicy: IfNotPresent
ports:
- containerPort: 3100
protocol: TCP
- containerPort: 7946
protocol: TCP
resources:
limits:
cpu: “5000m”
memory: “10000Mi”
requests:
cpu: “10m”
memory: “100Mi”
volumeMounts:
- mountPath: /conf
- mountPath: /var/tempo
terminationGracePeriodSeconds: 30
volumes:
- configMap:
defaultMode: 420
items:
- key: tempo.yaml
path: tempo.yaml
- key: overrides.yaml
path: overrides.yaml
- emptyDir: {}
apiVersion: apps/v1
kind: Deployment
metadata:
labels:
annotations:
spec:
minReadySeconds: 10
replicas: 1
selector:
matchLabels:
template:
metadata:
labels:
annotations:
spec:
containers:
- args:
- -target=distributor
ports:
protocol: TCP
protocol: TCP
- containerPort: 55681
protocol: TCP
- containerPort: 4317
readinessProbe:
failureThreshold: 3
httpGet:
path: /ready
port: http-metrics
scheme: HTTP
initialDelaySeconds: 30
periodSeconds: 10
successThreshold: 1
timeoutSeconds: 1
resources:
limits:
cpu: 4000m
memory: 6000Mi
requests:
cpu: 10m
memory: 500Mi
volumeMounts:
- mountPath: /conf
affinity:
podAntiAffinity:
requiredDuringSchedulingIgnoredDuringExecution:
- labelSelector:
matchLabels:
topologyKey: kubernetes.io/hostname
preferredDuringSchedulingIgnoredDuringExecution:
- weight: 100
podAffinityTerm:
labelSelector:
matchLabels:
topologyKey: failure-domain.beta.kubernetes.io/zone
volumes:
- configMap:
defaultMode: 420
items:
- key: tempo.yaml
path: tempo.yaml
- emptyDir: {}
apiVersion: apps/v1
kind: Deployment
metadata:
labels:
annotations:
spec:
minReadySeconds: 10
replicas: 1
selector:
matchLabels:
strategy:
rollingUpdate:
maxSurge: 0
maxUnavailable: 1
template:
metadata:
labels:
annotations:
spec:
containers:
- args:
- -target=querier
ports:
protocol: TCP
protocol: TCP
resources:
limits:
cpu: 3000m
memory: 3000Mi
requests:
cpu: 10m
memory: 100Mi
volumeMounts:
- mountPath: /conf
affinity:
podAntiAffinity:
- labelSelector:
matchLabels:
- weight: 100
podAffinityTerm:
labelSelector:
matchLabels:
volumes:
- configMap:
defaultMode: 420
items:
- key: tempo.yaml
path: tempo.yaml
- emptyDir: {}
apiVersion: apps/v1
kind: Deployment
metadata:
labels:
app.kubernetes.io/version: “2.6.1”
annotations:
spec:
minReadySeconds: 10
replicas: 1
selector:
matchLabels:
strategy:
rollingUpdate:
maxSurge: 0
maxUnavailable: 1
template:
metadata:
labels:
annotations:
spec:
containers:
- args:
- -target=query-frontend
ports:
protocol: TCP
- containerPort: 9095
resources:
limits:
cpu: 3000m
memory: 3000Mi
requests:
cpu: 10m
memory: 100Mi
volumeMounts:
- mountPath: /conf
- args:
- --http.base-path={{ .Values.global.tracing.jaeger.path | default “/” }}
- --grpc-storage-plugin.configuration-file=/conf/tempo-query.yaml
- --query.bearer-token-propagation=true
image: grafana-tempo-query-2.6.1
ports:
- containerPort: 16686
- containerPort: 16685
- containerPort: 16687
resources:
limits:
cpu: 3000m
memory: 3000Mi
requests:
cpu: 10m
memory: 50Mi
volumeMounts:
- mountPath: /conf
affinity:
podAntiAffinity:
- labelSelector:
matchLabels:
- weight: 100
podAffinityTerm:
labelSelector:
matchLabels:
volumes:
- configMap:
defaultMode: 420
items:
- key: tempo.yaml
path: tempo.yaml
- key: tempo-query.yaml
path: tempo-query.yaml
- emptyDir: {}
apiVersion: apps/v1
kind: StatefulSet
metadata:
labels:
annotations:
spec:
podManagementPolicy: Parallel
replicas: 3
selector:
matchLabels:
serviceName: ingester
updateStrategy:
type: RollingUpdate
template:
metadata:
labels:
annotations:
spec:
containers:
- args:
- -target=ingester
ports:
- name: grpc
containerPort: 9095
- name: http-memberlist
containerPort: 7946
protocol: TCP
containerPort: 3100
protocol: TCP
readinessProbe:
failureThreshold: 3
httpGet:
path: /ready
port: http-metrics
scheme: HTTP
periodSeconds: 10
successThreshold: 1
timeoutSeconds: 1
resources:
limits:
cpu: 5000m
memory: 15000Mi
requests:
cpu: 10m
memory: 500Mi
volumeMounts:
- mountPath: /conf
terminationGracePeriodSeconds: 300
affinity:
podAntiAffinity:
- labelSelector:
matchLabels:
- weight: 100
podAffinityTerm:
labelSelector:
matchLabels:
volumes:
- configMap:
defaultMode: 420
items:
- key: tempo.yaml
path: tempo.yaml
- emptyDir: {}
apiVersion: apps/v1
kind: StatefulSet
metadata:
labels:
annotations:
spec:
podManagementPolicy: OrderedReady
replicas: 1
selector:
matchLabels:
serviceName: memcached
template:
metadata:
labels:
annotations:
spec:
containers:
- image: bitnami-memcached-1.6.30
ports:
- containerPort: 11211
protocol: TCP
resources:
limits:
cpu: 3000m
memory: 3000Mi
requests:
cpu: 10m
memory: 30Mi
affinity:
podAntiAffinity:
- labelSelector:
matchLabels:
- weight: 100
podAffinityTerm:
labelSelector:
matchLabels:
updateStrategy:
type: RollingUpdate
#VirtualService
apiVersion: networking.istio.io/v1alpha3
kind: VirtualService
metadata:
spec:
hosts:
- ‘{{ .Values.global.dns }}.{{ .Values.global.domain }}’
gateways:
- {{ .Values.global.namespace }}/namespace-gw
http:
- match:
- uri:
prefix: {{ .Values.global.tracing.jaeger.path }}/
rewrite:
uri: {{ .Values.global.tracing.jaeger.path }}/
route:
- destination:
host: tempo-query-frontend.{{ .Values.global.namespace }}.svc.cluster.local
port:
number: 16686
