Tempo Helm Chart Ingress crashes container
Hi!
Whenever we try to enable the ingress on the “queryFrontend” the container (tempo-query) just crashes and it’s not working.
Our values.yaml config for the Ingress is the following:
queryFrontend:
query:
enabled: true
nodeSelector:
nodetype: observability
ingress:
enabled: true
ingressClassName: nginx
annotations: {}
hosts:
- host: xxxxx
paths:
- path: /
pathType: Prefix
tls:
- secretName: tempo-query-tls
hosts:
- xxxxx
We found the following error in the logs of the tempo-query container:
{“level”:“fatal”,“ts”:1694089793.4802585,“caller”:“./main.go:109”,“msg”:
“Failed to init storage factory”,“error”:"grpc-plugin builder failed to create a store: error attempting to connect to plugin rpc client: Unrecognized remote plugin message:
This usually means the plugin was not compiled for this architecture, the plugin is missing dynamic-link libraries necessary to run, the plugin is not executable by this process due to file permissions, or the plugin failed to negotiate the initial go-plugin protocol handshake
We looked for any template config related to the ingress of queryFronted and we couldn’t find anything.
Any help or advice would be appreciated.
Kind regards.
