Tempo query-frontend deployment error
I am getting below error while deploying tempo helm chart in gke cluster.
[ERROR] tempo-query: failed to parse configuration file: @module=jaegaer-tempo error=“open/conf/tempo-query.yaml: no such file or directory”
I did tried below steps to add variable and extravolumes with that i am getting different error
Error: UPGRADE FAILED: cannot patch “tempo-query-frontend” with kind Deployment: Deployment.apps “tempo-query-frontend” is invalid: spec.temlate.spec.template.spec.containers[1].volumemounts[1].name: Not found: “tmp2”
