grafana 8.1 on synology -
add plugins -
by downloading the plugin zip file and extracted in grafana plugins folder -
What happened?
it says files not found -
expected the plugin to work -
EROR[07-02|21:10:45] Could not find plugin file
logger=context userId=1 orgId=1 uname=admin error="open /var/lib/grafana/plugins/grafana-worldmap-panel/module.js: no such file or directory" -
Error loading: grafana-worldmap-panel -
i followed this to install grafana on synology
Grafana Docker for Home Assistant on Synology - #003 - YouTube
the file clearly is there, but it’s can’t see it for some reason
