Grafana v8.5.2
OS: CentOS Linux 7 (Core) -
I’m trying to build a panel plugin, followed these instructions: https://grafana.com/tutorials/build-a-panel-plugin/ -
I’ve set my environment, and followed ** Create a new plugin** 1-6. -
What happened?
I couldn’t find the new plugin at the Configuration → Plugins of the Grafana UI.
searched the log for plugins, and where the configuration are taken from:
logger=settings t=2022-05-23T12:41:26.81+0000 lvl=info msg=“Config loaded from” file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2022-05-23T12:41:26.81+0000 lvl=info msg=“Config loaded from” file=/etc/grafana/grafana.ini
logger=settings t=2022-05-23T12:41:26.81+0000 lvl=info msg=“Config overridden from command line” arg=“default.paths.plugins=/var/lib/grafana/plugins”
logger=settings t=2022-05-23T12:41:26.81+0000 lvl=info msg=“Path Plugins” path=/home/rnd/grafana-plugins
logger=plugin.finder t=2022-05-23T12:41:26.86+0000 lvl=warn msg=“Error occurred when checking if plugin directory exists” path=/home/rnd/grafana-plugins err=“stat /home/rnd/grafana-plugins: permission denied”
logger=plugin.finder t=2022-05-23T12:41:26.86+0000 lvl=warn msg=“Skipping finding plugins as directory does not exist” path=/home/rnd/grafana-plugins
tried to list the plugins using the cli:
$ grafana-cli plugins ls
Error: ✗ stat /var/lib/grafana/plugins: no such file or directory
fro that point i assumed i’m in a configuration mess which i tried to solve with no success ![]()
- to see my new plugin at the grafana ui Configuration → Plugins
- grafana logs - to see an info line for registering my new plugin.
- to list the plugins using “grafana-cli plugins ls” command
- Can you copy/paste the configuration(s) that you are having problems with?
Directory where grafana will automatically scan and look for plugins
#;plugins = /var/lib/grafana/plugins
plugins = /home/rnd/grafana-plugins
$ ll /home/rnd/grafana-plugins
total 4
drwxrwxr-x. 6 grafana grafana 214 May 23 09:35 new-panel-plugin
drwxrwxr-x. 2 grafana grafana 29 May 23 07:45 node_modules
drwxrwxr-x. 6 grafana grafana 214 May 23 08:08 test-plugin
-rwxrwxr-x. 1 grafana grafana 86 May 23 07:45 yarn.lock
- why Gragana cannot find in / has permission denied to “/home/rnd/grafana-plugins”
- why all the plugins are located in /usr/share/grafana/public/app/plugins/ directory, while the cli looks in /var/lib/grafana/plugins directory?
logger=plugin.finder t=2022-05-23T12:41:26.86+0000 lvl=warn msg=“Skipping finding plugins as directory does not exist” path=/home/rnd/grafana-plugins -
Ohhhh, many, but i’m a new user so i cannot publish them
