Hi! I’m trying to upload the next dashboard to grafana, however the error says that it needs a name. I’ve dowloaded it first, I deleted it and then I wanted to uploaded it. Send some help please! Thank you very much. And this is the error:
"meta": {
"type": "db",
"canSave": true,
"canEdit": true,
"canAdmin": true,
"canStar": true,
"slug": "replace_master_bms-automatico",
"url": "/d/W-BPM21-00019/replace_master_bms-automatico",
"expires": "0001-01-01T00:00:00Z",
"created": "2021-11-09T10:20:11Z",
"updated": "2021-11-09T10:21:07Z",
"updatedBy": "",
"createdBy": "",
"version": 2,
"hasAcl": false,
"isFolder": false,
"folderId": 0,
"folderUid": "",
"folderTitle": "General",
"folderUrl": "",
"provisioned": false,
"provisionedExternalId": ""
"dashboard": {
"annotations": {
"list": [
"builtIn": 1,
"datasource": "-- Grafana --",
"enable": true,
"hide": true,
"iconColor": "rgba(0, 211, 255, 1)",
"name": "Annotations & Alerts",
"type": "dashboard"
"editable": true,
"gnetId": null,
"graphTooltip": 0,
"id": null,
"links": [],
"panels": [
"collapsed": true,
"datasource": null,
"gridPos": {
"h": 1,
"w": 24,
"x": 0,
"y": 0
"id": 14,
"panels": [
"datasource": null,
"fieldConfig": {
"defaults": {
"color": {
"mode": "palette-classic"
"custom": {
"hideFrom": {
"legend": false,
"tooltip": false,
"viz": false
"mappings": [
"options": {
"0": {
"color": "rgba(255, 255, 255, 1)",
"index": 0,
"text": "Init"
"1": {
"color": "rgba(49, 153, 255, 1)",
"index": 1,
"text": "Ready"
"2": {
"color": "rgba(83, 217, 64, 1)",
"index": 2,
"text": "Active"
"3": {
"color": "rgba(235, 57, 57, 1)",
"index": 3,
"text": "Failure"
"null": {
"color": "semi-dark-yellow",
"index": 4,
"text": "Empty"
"type": "value"
"unit": "dateTimeAsIso"
"overrides": []
"gridPos": {
"h": 6,
"w": 5,
"x": 0,
"y": 1
"id": 18,
"options": {
"displayLabels": [
"value"
"legend": {
"displayMode": "hidden",
"placement": "bottom",
"values": [
"value"
"pieType": "pie",
"reduceOptions": {
"calcs": [
"last"
"fields": "",
"values": false
"tooltip": {
"mode": "multi"
"pluginVersion": "8.0.5",
"targets": [
"query": "SELECT last(batteryStatus_MainStatus)\nFROM \"autogen\".\"W-BPM21-00019\"",
"rawQuery": true,
"refId": "A"
"title": "System Status",
"transformations": [],
"type": "piechart"
"datasource": null,
"fieldConfig": {
"defaults": {
"color": {
"mode": "thresholds"
"displayName": "SoH",
"mappings": [],
"max": 100,
"min": 70,
"thresholds": {
"mode": "absolute",
"steps": [
"color": "semi-dark-orange",
"value": null
"color": "light-blue",
"value": 80
"color": "light-yellow",
"value": 90
"unit": "percent"
"overrides": []
"gridPos": {
"h": 6,
"w": 5,
"x": 5,
"y": 1
"id": 24,
"options": {
"reduceOptions": {
"calcs": [
"mean"
"fields": "",
"values": false
"showThresholdLabels": false,
"showThresholdMarkers": true,
"text": {}
"targets": [
"query": "SELECT last(\"SoH\") \nFROM \"autogen\".\"W-BPM21-00019\"",
"rawQuery": true,
"refId": "A"
"id": "calculateField",
"options": {
"mode": "reduceRow",
"reduce": {
"include": [
"W-BPM21-00019.last"
"reducer": "mean"
"replaceFields": true
"type": "gauge"
"datasource": null,
"fieldConfig": {
"defaults": {
"color": {
"displayName": "SoC",
"mappings": [],
"max": 100,
"min": 0,
"thresholds": {
"mode": "absolute",
"steps": [
"color": "super-light-blue",
"value": null
"color": "super-light-green",
"value": 15
"color": "semi-dark-green",
"value": 60
"color": "dark-green",
"value": 85
"color": "semi-dark-red",
"value": 95
"unit": "percent"
"overrides": []
"gridPos": {
"h": 6,
"w": 5,
"x": 10,
"y": 1
"id": 26,
"options": {
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"text": {}
"targets": [
"query": "SELECT last(\"SoC\") \nFROM \"autogen\".\"W-BPM21-00019\"",
"rawQuery": true,
"refId": "A"
"options": {
"reduce": {
"include": [
"reducer": "mean"
"type": "gauge"
"datasource": null,
"fieldConfig": {
"defaults": {
"color": {
"custom": {
"align": "auto",
"displayMode": "auto"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": []
"gridPos": {
"h": 6,
"w": 9,
"x": 15,
"y": 1
"id": 22,
"options": {
"showHeader": true
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"measurement": "W-BPM21-00019",
"orderByTime": "ASC",
"policy": "default",
"query": "SELECT event_code, event_descr, event_cells\nFROM \"autogen\".\"W-BPM21-00019\"\nWHERE $timeFilter \n",
"rawQuery": true,
"refId": "A",
"resultFormat": "table",
"select": [
"params": [
"event_0"
"type": "field"
"tags": []
"title": "Events Pannel",
"type": "table"
"datasource": null,
"fieldConfig": {
"defaults": {
"color": {
"displayName": "Hardware",
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"unit": "none"
"overrides": []
"gridPos": {
"h": 1,
"w": 5,
"x": 0,
"y": 7
"id": 33,
"options": {
"colorMode": "value",
"graphMode": "area",
"justifyMode": "auto",
"orientation": "vertical",
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"text": {
"titleSize": 20,
"valueSize": 30
"textMode": "auto"
"targets": [
"alias": "",
"query": "SELECT last(hw) as \"Hardware\"\nFROM \"autogen\".\"W-BPM21-00019\"\nWHERE $timeFilter",
"rawQuery": true,
"refId": "A",
"resultFormat": "time_series"
"timeFrom": null,
"timeShift": null,
"type": "stat"
"datasource": null,
"fieldConfig": {
"defaults": {
"color": {
"displayName": "Voltage",
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "dark-orange",
"value": null
"unit": "volt"
"overrides": []
"gridPos": {
"h": 6,
"w": 5,
"x": 5,
"y": 7
"id": 28,
"options": {
"reduceOptions": {
"calcs": [
"mean"
"fields": "",
"values": false
"text": {}
"targets": [
"query": "SELECT last(\"battery_voltage\") \nFROM \"autogen\".\"W-BPM21-00019\"",
"rawQuery": true,
"refId": "A"
"options": {
"reduce": {
"include": [
"reducer": "mean"
"type": "gauge"
"datasource": null,
"fieldConfig": {
"defaults": {
"color": {
"decimals": 0,
"displayName": "Current",
"mappings": [],
"max": 36,
"min": -36,
"thresholds": {
"mode": "absolute",
"steps": [
"color": "semi-dark-blue",
"value": null
"value": 0
"unit": "amp"
"overrides": []
"gridPos": {
"h": 6,
"w": 5,
"x": 10,
"y": 7
"id": 30,
"options": {
"reduceOptions": {
"calcs": [
"last"
"fields": "",
"values": false
"text": {}
"targets": [
"query": "SELECT last(\"battery_current\") \nFROM \"autogen\".\"W-BPM21-00019\"",
"rawQuery": true,
"refId": "A"
"options": {
"reduce": {
"include": [
"reducer": "sum"
"type": "gauge"
"datasource": null,
"fieldConfig": {
"defaults": {
"color": {
"custom": {
"align": "auto",
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": []
"gridPos": {
"h": 6,
"w": 9,
"x": 15,
"y": 7
"id": 53,
"options": {
"showHeader": true
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"query": "SELECT error_code, error_descr, error_cells\nFROM \"autogen\".\"W-BPM21-00019\"\nWHERE $timeFilter \n",
"rawQuery": true,
"refId": "A",
"select": [
"params": [
"event_0"
"type": "field"
"tags": []
"title": "Errors Pannel",
"type": "table"
"datasource": null,
"fieldConfig": {
"defaults": {
"color": {
"displayName": "Software",
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"unit": "none"
"overrides": []
"gridPos": {
"h": 1,
"w": 5,
"x": 0,
"y": 8
"id": 34,
"options": {
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"text": {
"titleSize": 20,
"valueSize": 30
"textMode": "auto"
"targets": [
"alias": "",
"query": "SELECT last(sw) as \"Software\"\nFROM \"autogen\".\"W-BPM21-00019\"\nWHERE $timeFilter",
"rawQuery": true,
"refId": "A",
"timeFrom": null,
"timeShift": null,
"type": "stat"
"datasource": null,
"fieldConfig": {
"defaults": {
"color": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": []
"gridPos": {
"h": 4,
"w": 5,
"x": 0,
"y": 9
"id": 16,
"options": {
"orientation": "auto",
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "/^Time$/",
"values": false
"text": {
"valueSize": 30
"textMode": "auto"
"targets": [
"query": "SELECT last(battery_current)\nFROM \"autogen\".\"W-BPM21-00019\"",
"rawQuery": true,
"refId": "A"
"title": "Last Data Received",
"options": {
"reduce": {
"include": [
"Time",
"reducer": "lastNotNull"
"type": "stat"
"title": "Battery Status",
"type": "row"
"collapsed": true,
"datasource": null,
"gridPos": {
"h": 1,
"w": 24,
"x": 0,
"y": 28
"id": 2,
"panels": [
"alert": {
"alertRuleTags": {},
"conditions": [
"evaluator": {
"params": [
2.5
"type": "gt"
"operator": {
"type": "and"
"query": {
"params": [
"A",
"5m",
"now"
"reducer": {
"params": [],
"type": "last"
"type": "query"
"executionErrorState": "alerting",
"for": "0",
"frequency": "1s",
"handler": 1,
"name": "Failure Alert alert",
"noDataState": "no_data",
"notifications": []
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"datasource": null,
"fill": 0,
"fillGradient": 0,
"gridPos": {
"h": 11,
"w": 11,
"x": 0,
"y": 7
"hiddenSeries": false,
"id": 52,
"legend": {
"avg": false,
"current": false,
"max": false,
"min": false,
"show": true,
"total": false,
"values": false
"lines": true,
"linewidth": 1,
"nullPointMode": "connected",
"options": {
"alertThreshold": true
"percentage": false,
"pointradius": 2,
"points": false,
"renderer": "flot",
"seriesOverrides": [],
"spaceLength": 10,
"stack": false,
"steppedLine": false,
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"query": "SELECT last(\"batteryStatus_MainStatus\") \nFROM \"W-BPM21-00019\"\nWHERE $timeFilter GROUP BY time($__interval) fill(null)",
"rawQuery": true,
"refId": "A",
"resultFormat": "time_series",
"select": [
"params": [
"batteryStatus_MainStatus"
"type": "field"
"tags": []
"thresholds": [
"colorMode": "critical",
"fill": true,
"line": true,
"op": "gt",
"value": 2.5,
"visible": true
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "Failure Alert",
"tooltip": {
"shared": true,
"sort": 0,
"value_type": "individual"
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"$$hashKey": "object:114",
"format": "short",
"label": null,
"logBase": 1,
"max": "3",
"min": "0",
"show": true
"$$hashKey": "object:115",
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"yaxis": {
"align": false,
"alignLevel": null
"title": "Customized",
"type": "row"
"refresh": false,
"schemaVersion": 30,
"style": "dark",
"tags": [],
"templating": {
"list": []
"time": {
"from": "now-7d",
"to": "now"
"timepicker": {},
"timezone": "",
"title": "W-BPM21-00019 AUTOMATICO",
"uid": "W-BPM21-00019",
"version": 2
