V7.5.10 -
We are using Grafana for monitoring. -
Using Grafana dashboards and components like table, heatmap etc. -
What happened?
Want to know the end of life support for v7.5.10 version. Any timelines for supporting security patches , bug fixes etc. for V7.5.10 . -
We will be supporting v7.5 for some time, but I would advise migrating to v8 sooner rather than later. There are so many enhancements, plus a few breaking changes, I think that the sooner you get 8+ the better, if you can.
