we are using 6.7.3 with SUSE 15.x -
We would like to know the end of support dates for Grafana 6.7.3 version. Also till when we will get the security fixes on Grafana 6.7.x version? -
What happened?
Hi @ericdeepti
trying to get some clarity on this. standby
