Grafana simply will not pick up the environment variables I am setting to overwrite the configuration files. I am trying to edit my SMTP password using an environment variable, but having no luck. I have also tried editing other settings, as shown in the documentation, which also does not seem to work.
10.4 -
Adding an SMTP password with the GF_SMTP_PASSWORD environment variable -
exoprt GF_SMTP_PASSWORD=my_pass
systemctl restart grafana-server -
What happened?
Grafana just does not see the environment variable at all -
I would expect the logs to at least see something related to the variable -
N/A -
No errors, which is kind of the problem. It looks as though it just does not see the variable. -
