Hello!
I have a Grafana OSS (v11.5.1) deployed in an EKS cluster with the default SQLite database using an AWS EFS volume.
I wanted to check the latency of the database queries and wanted to enable instrument_queries but got the following error:
Error: ✗ provide Resource DB: the Resource API is attempting to
leverage the database from core Grafana defined in the
[database] INI section since a database configuration was not
provided in the [resource_api] section. But we detected that the
key `instrument_queries` is enabled in [database], and that
setup is currently unsupported. Please, consider disabling
that flag
Excerpt of the Helm Chart’s values yaml file:
grafana:
grafana.ini:
database:
log_queries: true
instrument_queries: true
# resource_api:
# db_log_queries: false
# db_type: sqlite3
After reading the previous error, I checked in the Administration → General → Settings this resource_api setting, but if try to set db_type: sqlite3, I got another error:
Error: ✗ provide Resource DB: invalid db type specified: sqlite3
I also enabled log_queries, but want to have Prometheus metrics if possible.
So, my question is, it is possible to instrument the queries with my current setup or I am doing something wrong?
Thank you for your help!
