Elasticsearch multiple queries, combining columns with different terms
I have a panel querying an Elasticsearch data source. I have two queries which use the exists query to determine which field to GroupBy. For example, the queries are:
Query 1
VOName:$vo AND ResourceType:$type AND exists:OIM_Facility
GroupBy: OIM_Facility
Query 2
VOName:$vo AND ResourceType:$type AND NOT exists:OIM_Facility
GroupBy: OIM_Site
When I display this in a table, I want to merge the OIM_Facility and OIM_Site columns. In a previous version of Grafana (4.6.3), they would merge automatically.
Grafana: 6.5.2
I also want to do something like this. Did you come across a solution?
No, I never found a solution.
I literally found a solution today, but only for Grafana 7.
In v7+ you can, when defining your queries, go to the Transformations tab and choose Merge. As long as you have two columns the same - one in each result set, it will merge the values.
Huh, that is not exactly what I was looking for. I was more looking for something that would do this
Query 1 result:
Facility Core Hours
Site 1 10
Site 2 30
Query 2 Result:
Facility Core Hours
Site 3 50
Site 4 70
And the final table would be:
Facility Core Hours
Site 1 10
Site 2 30
Site 3 50
Site 4 70
There would be no duplicate in the Facility column.
