- Grafana Version: v9.1.6
- OS: Kubernetes, Deployed Through Helm
- What are you trying to achieve?
- Add Elastic Search datasource through YAML format in the helm chart deployment
- How are you trying to achieve it?
# Setup Data Source (prometheus)
datasources:
datasources.yaml:
apiVersion: 1
datasources:
- name: Prometheus
type: prometheus
url: http://prometheus-server
access: proxy
isDefault: true
- name: Elastic
type: elasticsearch
url: http://elasticsearch-master:9200
password: ""
user: ""
access: proxy
isDefault: false
jsonData:
indexName: vds_server_access.log*
esVersion: 7.10+
logLevelField: ""
logMessageField: ""
maxConcurrentShardRequests: 5
timeField: "@timestamp"
readonly: false
- I am unable to set the indexName field
- Set the indexName field in the dashboard datasource through yaml in the helm chart
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Try database field, example:
- name: Elasticsearch
type: elasticsearch
access: proxy
url: <url>
basicAuth: true
basicAuthUser: <user>
database: <index name>
isDefault: false
jsonData:
esVersion: 7.10.0
logMessageField: full_message
timeout: 300
tlsSkipVerify: true
maxConcurrentShardRequests: 10
secureJsonData:
basicAuthPassword: <password>
I would recommend to check doc - there are some good examples usually.
You may configure datasource manually and then check response from API (/api/datasources) - that particular datasource JSON structure can be mapped to YAML tructure easily (except secrets-secureJsonData, which has special secure handling).
@jangaraj Thank You that information was really helpful
thanks @jangaraj that worked!
