I have Grafana working with Prometheus as default datasource. Want to add Elasticsearch as a secondary data source. My environment is running in kubernetes with Elasticsearch : 7.2.0 , Grafana : 6.4.4
But getting error No date field named undefined found
I am able to curl ‘http://elasticsearch:9200/_cat/indices?v&pretty’ from Grafana pod
Indices
root@shell-545fcb88cc-grn9t:/# curl -XGET 'http://elasticsearch:9200/_cat/indices?v&pretty'
health status index uuid pri rep docs.count docs.deleted store.size pri.store.size
green open .monitoring-es-7-2019.11.08 ULAdvIYIRxCEGewgc3IA3g 1 1 314892 240982 732.5mb 361.3mb
green open syslog-2019.11.03 hfPuNniuTaKiKm6LZYazCg 1 1 277 0 386.9kb 193.4kb
green open apm-7.2.0-2019.11.06 LtLGo-2aTjGlSIzhlfkoZw 1 1 39783 7578 12.3mb 6.1mb
green open .monitoring-kibana-7-2019.11.07 FeFhr8-5QRO6VzYu-c1s7w 1 1 17278 0 6.3mb 3.1mb
green open .monitoring-kibana-7-2019.11.02 CVlb1_0yQEaV-V92hIvspg 1 1 17278 0 5.7mb 2.8mb
green open syslog-2019.11.05 JutF5UINTJaencoQ2TDllg 1 1 636 0 664.5kb 332.2kb
green open .monitoring-kibana-7-2019.11.03 kTwQsBCOTtK2l04dQ9Ox_g 1 1 17280 0 5.7mb 2.8mb
green open syslog-2019.10.31 PynRH8ZMT0OwwpEKOvJgwg 1 1 42 0 164.1kb 82kb
green open .monitoring-logstash-7-2019.11.02 5a1shQN6SQaPMyETlEWI6w 1 1 129555 0 13.8mb 6.9mb
green open filebeat-7.2.0-2019.10.03-000002 hhi_PGsaRWu9W2Lb565cyg 1 1 24963987 0 20.2gb 10.1gb
green open metricbeat-7.2.1-2019.10.03-000002 2ek3X0h-R5ONjD51sVcOCg 1 1 2757322 0 1gb 552.9mb
green open .monitoring-es-7-2019.11.07 Mzgl3oj6Rv6ruPs-suqN-w 1 1 459545 181138 608.5mb 304.6mb
green open .monitoring-kibana-7-2019.11.05 36IX0HsWR5SLZttFv2Dc2g 1 1 17278 0 6.5mb 3.2mb
green open apm-7.2.0-2019.11.07 2I50pf3pRoGzMWkBvnR8zg 1 1 307629 0 56.7mb 28.3mb
green open .monitoring-logstash-7-2019.11.08 zCClqPcRSG-nVjOACuRUPA 1 1 85350 0 9.4mb 4.7mb
green open .monitoring-logstash-7-2019.11.03 jSwDSoyMQD25Hl3dH2kvZQ 1 1 129555 0 13.7mb 6.8mb
green open syslog-2019.11.02 e9mcQ3KYS3yfegO7i6pn9g 1 1 319 0 475.4kb 237.7kb
green open metricbeat-7.2.0-2019.10.22-000003 ssCSFuT0QaikLW8OiKP1Kw 1 1 120115580 0 79.2gb 39.6gb
green open .monitoring-es-7-2019.11.02 uqxh6Dv2QyK5u75MpiRFNg 1 1 379582 33600 477.6mb 239mb
green open .kibana_1 qDMwS82NShi-ZCgj2ZNnaw 1 1 33 10 453kb 226.5kb
green open .monitoring-kibana-7-2019.11.04 J5CQ71GzTgiiWXu-Ih22XA 1 1 17278 0 6.4mb 3.2mb
green open .monitoring-logstash-7-2019.11.04 9gtK9qK0RQOjt12mtVlpyA 1 1 129555 0 14.9mb 7.3mb
green open syslog-2019.11.07 PcdvTxMRTnqS0ZUBlyK1rA 1 1 8538 0 5mb 2.5mb
green open filebeat-7.2.0-2019.11.02-000003 4MIsjbyKQ52DVxOUxeM9AQ 1 1 6350545 0 4.7gb 2.3gb
green open filebeat-7.2.0-2019.09.03-000001 eYZWZhv0RjybEkkUImJIiQ 1 1 25802336 0 21.3gb 10.6gb
green open syslog-2019.10.30 e6m-tWt2S7S5fx739HIvCA 1 1 1143 0 823.7kb 419kb
green open metricbeat-7.2.1-2019.11.02-000003 iVEXirNxTJWbz8aCmpDENA 1 1 0 0 566b 283b
green open .monitoring-es-7-2019.11.06 LUG3w4KGRyiuEId4qAlFNA 1 1 435635 136350 574mb 286.5mb
green open .monitoring-es-7-2019.11.05 -EWrrs-STd2lOWor_3NSow 1 1 425016 116530 581.7mb 282mb
green open .kibana_task_manager h6Esmg1eQBSaCNlQKljl9w 1 1 2 0 42.9kb 21.4kb
green open .monitoring-kibana-7-2019.11.06 80-uL-omQIKUHo2okewPSQ 1 1 17280 0 6.4mb 3.2mb
green open .monitoring-logstash-7-2019.11.06 VlDIxdShTGyU4xaZsvqVpw 1 1 129555 0 14.3mb 7.1mb
green open syslog-2019.11.08 jPJuTD7SRQqaTcmVuzlNBA 1 1 2914 0 1.7mb 1.2mb
green open .monitoring-es-7-2019.11.03 UdEsVrDmR762mzxhUl2fGw 1 1 407665 84050 503.9mb 253.9mb
green open apm-7.2.0-2019.09.16 xnXXNE1pSmGClsYKrSJuHg 1 1 2 0 13kb 6.5kb
green open filebeat-7.2.1-2019.09.03-000001 I8vRGDnrR-6Cl5oPwCzjuw 1 1 4651714 0 3.4gb 1.7gb
green open metricbeat-7.2.0-2019.09.03-000001 abOCdQ4WTS62M75gpG6qkA 1 1 149807959 0 100gb 50gb
green open .monitoring-logstash-7-2019.11.05 VlbH_i3nRNCBO5VYW8VxoA 1 1 129540 0 14.4mb 7.3mb
green open metricbeat-7.2.0-2019.09.28-000002 uYvCxqH7SpSKDYDdF1z_Rg 1 1 151770825 0 100gb 50gb
green open syslog-2019.11.06 9onA0R_qTTKeroZvGlKCIg 1 1 3098 0 2.6mb 1.3mb
green open metricbeat-7.2.1-2019.09.03-000001 ZQ3-urydTn2kMhYDPtRqYQ 1 1 8700321 0 3.7gb 1.8gb
green open filebeat-7.2.1-2019.10.03-000002 Xkwv7LQVSm6yVqBSZKVKCg 1 1 389496 0 285.6mb 143.2mb
green open .monitoring-logstash-7-2019.11.07 nKLFM9HxSLGEwAvnu48p_w 1 1 129555 0 14.8mb 7.4mb
green open filebeat-7.2.1-2019.11.02-000003 5PwPy8jRQEC3bmW9hFctxg 1 1 0 0 566b 283b
green open .monitoring-es-7-2019.11.04 vxoKsjlZSTGq3WzTeHbr7Q 1 1 416188 99708 539.7mb 270.6mb
green open syslog-2019.11.01 wFgiLIxgQ9m4R8c1plR6UQ 1 1 943 0 933kb 457.6kb
green open apm-7.2.0-2019.11.08 rfwNhFJyR1mRdssXNRp73A 1 1 205015 0 37.7mb 18.8mb
green open syslog-2019.11.04 OoaAXVTwRhiJfMlCFqI27Q 1 1 1469 0 1.3mb 713.4kb
green open .monitoring-kibana-7-2019.11.08 npniaHZzR4SFW4OxTjzldQ 1 1 11374 0 4.2mb 2.1mb
Data Sources / Elasticsearch
HTTP
URL : http://elasticsearch:9200
Access : Server (Default)
Auth
No auth is selected.
Elasticsearch details
Index name : metricbeat-7.2.0-2019.10.22-000003
Pattern : No pattern
Time field name : @timestamp
Version : 7.0+
Max concurrent Shard Requests : 5
Min time interval : 10s
Logs
Message field name : (Blank)
Level field name : (Blank)
For now I just want to get metricbeat logs. How can I get this working , Also can I specify wildcard index name ?
