Elasticsearch datasource provisioning just...fails
Hello Everyone,
I have recently just started using elasticsearch with grafana and when I manually provision a datasource…it works just fine.
I duplicated all of the settings from the UI in my datasource yaml, however, it seems to not want to work. The connetion fails each time (see screenshot).
apiVersion: 1        datasources:        - name: Elasticsearch        type: elasticsearch        access: proxy        basicAuth: true        basicAuthUser: elastic        url: https://elasticsearch:9200        secureJsonData:        basicAuthPassword: changeme        jsonData:        index: '[metrics-]YYYY.MM.DD'        interval: Daily        timeField: '@timestamp'        tlsSkipVerify: true
We are using TLS as the elasticseach instance will reside on another host.
Not sure where I went wrong, but if anyone has any insight please let me know :slight_smile:
Thanks a bunch in advance!
Best Regards,
Chris W.
Please follow instruction and check your server logs first to see what’s a problem.
Also I’m missing how yaml (which creates broken datasource) and working datasource looks like, grafana version,… (all details to have reproducible example).
Check this out
Thank you, I have seen the documentation. I am going to add it manually for now, it seems to work fine.
