Sort on Raw document is not available ??
If so I want to add one row to the table, need to have the respective row value for another attribute
We can achieve with via one more group by but the limitation is ES not able to query a long string
So is it possible to know the respective value of another attribute of that ES document using any option ES plugin
Using Grafana V6.6.2
