ElasticSearch return latest document
Hi Grafana community,
I’m trying to do something in Grafana and I am not even sure if it’s supported. We are using Grafana version 5.2.4 with ElasticSearch 6.2 and what I’ve been asked to do is to create a table panel with the values for specific fields in our ElasticSearch data. The issue I’m trying to overcome is that I only want the values (which are generally text) for the latest version of the event. I have a “documentId” field and essentually I want to return only the latest event containing that documentId when displaying the data for the table. I think I need to do some kind of term aggregation on documentId, but when I use “Raw Document” for the metric so I can create the table, there is no way to aggregate on the documentId that I can see. The only thing I can set there is the size (number of returned events).
Am I missing something on how to do this? Am I providing enough information?
Thanks,
Jared
Let me give a little more info. Say I have this data in elasticsearch:
{ “documentId”: 1, “data”: { “text”:“hello”, “user”:“bob”}, “@timestamp”: “2019-06-11 08:34:24” }
{ “documentId”: 2, “data”: { “text”:“hi”, “user”:“sam”}, “@timestamp”: “2019-06-11 08:35:34” }
{ “documentId”: 3, “data”: { “text”:“greetings”, “user”:“mary”}, “@timestamp”: “2019-06-11 08:35:37” }
{ “documentId”: 1, “data”: { “text”:“hola”, “user”:“bob”}, “@timestamp”: “2019-06-11 08:37:54” }
{ “documentId”: 4, “data”: { “text”:“hello”, “user”:“joan”}, “@timestamp”: “2019-06-11 08:38:01” }
{ “documentId”: 2, “data”: { “text”:“howdy”, “user”:“sam”}, “@timestamp”: “2019-06-11 08:38:11” }
I would want a table with only the most recent data from each document, so it would show document 2 for instance, but it would have only the data from the last line in the example since it’s newer.
Is that even possible with “Raw Document” as the metric?
Thanks,
Jared
