-Version * [v9.3.6]
- What are you trying to achieve?
-I have created many dashboard (time series, gauges) and i didn’t find a way to set a dynamic threshold from a table (sql). normally, i have 3 sets of threshold (advise, warning, critical) with 3 different colors. Here’s an exemple:
The value of the threshold can change for a panel to another one and can be modify in time. It could be fantastic to be able to map a threshold with is color from a table.
Let me know if someone is able to do what i want.
best regards,
Mathieu
