Dual Y-Axis tab disappeared in Color pop-up
Hallo,
In version 7.4 , the Color pop-up window (color selection of the time series lines) had 3 tabs, 1 of which was Y-axis. In version 8.0.3 this is missing. How can a dual Y-axis now be added?
Greetings
you need to override the series
and give them 2 different Standard Options: Unit & Axes Placement: Right/Left/Auto
to put them into 2 different Y axes
Okay that works fine! More complicated but okay!
However it seems that both curves are now linked together as you can’t see them individualy anymore!
Is there a fix?
