Grafana Cloud -
I want to create a dropdown variable at the top of the dashboard, showing tag values from a measurement in InfluxDB. -
I made a variable with type: query and set the query to:SHOW TAG VALUES ON "example-db" WITH KEY = "site" -
What happened?
The variable is empty, no values can be selected.
I expected to see a list of tags, similar to what this query returns in the Explore page.
Documentation here: Explore your schema using InfluxQL | InfluxDB OSS v1 Documentation
