Downloading and running Grafana locally
    11.2.0 and MacOS
  • What happened?
    It is throwing me the error
    curl: (28) Failed to connect to dl.grafana.com port 443 after 75531 ms: Couldn’t connect to server
what is your geo location?
can you curl the address on 443 and see what response you get?
