Hey folks,
What is the last version of the grafana/grafana docker image that is still on the Apache license?
Hey folks,
Hi @somtochiama just wanted to point you to Grafana relicensing to AGPLv3 - question on versions - #14 by mattabrams in case you haven’t seen that already. I would assume that the docker images are licensed the same way as the code that is packaged (unless stated otherwise somewhere?)
@somtochiama, I’m getting extra clarity from our licensing team about this but I am quite confident that @svetb’s answer is correct.
The original repo that held the Dockerfile and build scripts for creating grafana images was outside the grafana/grafana repo. This repo was Apache2. That repo was archived and the files were added to the main grafana/grafana repo years ago, so they are since licensed the same as any other files in any other grafana/grafana release.
By extension, as Svet said, I believe that our docker images inherit whatever license the packaged code is under at that point in time.
As I said, I will get extra confirmation here, but basically: the grafana/grafana:7.5.5
docker image should have inherited the Apache2 license from the underlying v7.5.5 code.
This will change for sure to AGPLv3 starting with Grafana V8
