I’m running Grafana 10.2.0 on Docker container and I’m searching for the Docker “env” counterpart of the grafana.ini parameter ‘oauth_allow_insecure_email_lookup’
I’ve looked for on Grafana’s documentation, but I didn’t find anything…
Does this env variable exist?
Could you help me to find it?
Thanks
I believe all config options can be env variables as well:
There is standardized syntax for them:
GF_<SectionName>_<KeyName>
so in this case it is:
GF_AUTH_OAUTH_ALLOW_INSECURE_EMAIL_LOOKUP
Thanks, It works! ![]()
