Display names for bar gauge (Series[0]...)
Hi all!
I have such data:
I wand to group the data by “series”. It’s ok if visualization type is Table:
But the type is Bar gauge labels of bars does not take needed values (3ЭС5К, 2ЭС5К, 2ТЭ116У):
Could you please say how to fix it?
Have you tried the variable form ${__series.keyword}? (TWO underscores)
I know in my v7 ${__series.name} outputs the name correctly (which is also the default if nothing specified).
Nope. Returns something strange
$__cell_0 worked
How can I added to the query?
I added to Display name
Thanks @albertugatu.
This is my issue:
I think using this macro I can join the 2 columns, can you please correct me if I am wrong?
Sorry, but I don’t know
