Table Series as Display Name without prefix
v10.0.3
I want to use the query name as the display name for each bar. It sort of works using ${__series.name} but wraps the name e.g. “Series(A)” instead of just “A”
By using ${__series.name}
  • What happened?
Bar was labelled “Series(A)”
Bar labelled “A”
