Hello.
I am trying to display a bar-gauge using only two fields of my query which contains 3 because I need this third field as a variable for a datalink.
Unfortunately I am not able to only diplay the second field as name of each bar…
Any suggestion ?
Thanks !
Hi @hlibotte,
Thank you for your post!
Would you mind adding more information about the datasource and the query that you are using? Some screenshots will be appreciated too.
