Disable "view in Azure portal" on point click
I am using Grafana v10.0.0. I am using Azure monitor as my data source. I want to disable “view in Azure portal” from tooltip when clicked on a point.
For bar carts, this appears on hover as well. I do not want users/viewers to be able to see the query.
we also facing same issue any workarround to disable Azure portal redirection?
we can disable this by override property in the pannel settings.
Pannel Options > Add field override > choose field with type
choose the override property “Data links” and keep it blank
Now the hyper links gets disabled
