This problem appears to coincide with the release of 9.4.7. We are hosting Grafana as a Docker image within Azure. We are using Azure Monitor as the data source.
Our master grafana dashboard loads fine and has a row of tiles for multiple environments. Usually, if I click on a row it will drill down into that particular environment but, for approx the past 10 days, it instead opens a tab in the Azure Portal with the query syntax in a query window.
I can still navigate to the dashboard I need to get to manually so I know the dashboards are 100% - it’s just the links that are broken (no changes made).
Anyone else seeing this?
