Grafana v12.0.2 on Docker -
Create a dashboard that visualizes logs, and allows for filtering using regex expressions, and it’s easy to read. -
Dashboard created successfully -
What happened?
All the entries in my dashboard appears highlighted
I want to avoid the highlighting. -
This is the query that I have at the moment:
{hostname=~“$hostname”,component=“loki.source.syslog”} |~$filter|~$free_form_filter
Pass result to some additional parser/filter, so it will drop somehow highlight metadata. IMHO there is no doc for that, but this works for me (you may need different LogQL, use my example as an idea, not a copy&paste solution):
| json | line_format `{{.body}}`
