Hi folks
Is there a way to link from an external system to the trace view for a particular tempo trace easily? Honeycomb for example has a /trace/<traceid> endpoint that just does the right thing to pull up a given traceid that you may have found from a different system, like a log or a HTTP header or something.
It’d be really great to be able to craft these links in automation tooling or similar to easily get to the context for a trace.
Thanks
