Hi All,
I am trying to display api response time in stat as well as Bar graph. I am using influx db as datasource. Trying to show the average value, but it’s showing a difference in the value displayed in stat and Bar graph. But if I open the stat in edit mode it will show the same value as that in the bar graph. Attaching the screenshot for reference. Thanks in advance
