Yea, i understood that too
Problem as i see it, the Postgres does not have a built in function / aggregate function for a difference() as Flux has. Also, flux has better cooperation with the graphs.
Thanks for the reply!
Here is the Postgres:
SELECT
time_bucket('3600.000s',"time") AS "time",
avg(act_energy_pos) AS "act_energy_pos"
FROM powermetrics
WHERE
"time" BETWEEN '2024-04-28T12:11:12.869Z' AND '2024-04-28T18:11:12.869Z'
GROUP BY 1
ORDER BY 1
Result
"request": {
"url": "api/ds/query",
"method": "POST",
"data": {
"queries": [
"refId": "A",
"datasource": {
"uid": "UyNygaBIz",
"type": "postgres"
"rawSql": "SELECT\n $__timeGroupAlias(\"time\",1h),\n avg(act_energy_pos) AS \"act_energy_pos\"\nFROM powermetrics\nWHERE\n $__timeFilter(\"time\")\nGROUP BY 1\nORDER BY 1",
"format": "time_series",
"datasourceId": 6,
"intervalMs": 60000,
"maxDataPoints": 1080
"range": {
"from": "2024-04-28T14:24:41.873Z",
"to": "2024-04-28T20:24:41.873Z",
"raw": {
"from": "now-6h",
"to": "now"
"from": "1714314281873",
"to": "1714335881873"
"hideFromInspector": false
"response": {
"results": {
"A": {
"frames": [
"schema": {
"refId": "A",
"meta": {
"executedQueryString": "SELECT\n time_bucket('3600.000s',\"time\") AS \"time\",\n avg(act_energy_pos) AS \"act_energy_pos\"\nFROM powermetrics\nWHERE\n \"time\" BETWEEN '2024-04-28T14:24:41.873Z' AND '2024-04-28T20:24:41.873Z'\nGROUP BY 1\nORDER BY 1"
"fields": [
"name": "Time",
"type": "time",
"typeInfo": {
"frame": "time.Time",
"nullable": true
"name": "act_energy_pos",
"type": "number",
"typeInfo": {
"frame": "float64",
"nullable": true
"data": {
"values": [
1714312800000,
1714316400000,
1714320000000,
1714323600000,
1714327200000,
1714330800000,
1714334400000
101823028.61320755,
101825447.29526462,
101831078.53333333,
101835502.73055556,
101840836.55555557,
101844852.23333333,
101847557.02702703
"refId": "A"
Here is the Flux:
from(bucket: "Metrics")
|> range(start: 2024-04-28T14:22:57.316Z, stop: 2024-04-28T20:22:57.316Z)
|> filter(fn: (r) => r["_measurement"] == "Electrical")
|> filter(fn: (r) => r["_field"] == "act_energy_pos")
|> aggregateWindow(every: 1h, fn: first, createEmpty: false)
|> difference()
Result:
"request": {
"method": "POST",
"data": {
"queries": [
"datasource": {
"uid": "2AcxRoKVz",
"type": "influxdb"
"query": "from(bucket: \"Metrics\")\n |> range(start: v.timeRangeStart, stop: v.timeRangeStop)\n |> filter(fn: (r) => r[\"_measurement\"] == \"Electrical\")\n |> filter(fn: (r) => r[\"_field\"] == \"act_energy_pos\")\n |> aggregateWindow(every: 1h, fn: first, createEmpty: false)\n |> difference()",
"refId": "A",
"datasourceId": 1,
"intervalMs": 20000,
"range": {
"from": "2024-04-28T14:23:34.925Z",
"to": "2024-04-28T20:23:34.925Z",
"raw": {
"from": "now-6h",
"to": "now"
"from": "1714314214925",
"to": "1714335814925"
"response": {
"results": {
"A": {
"frames": [
"schema": {
"name": "Electrical",
"refId": "A",
"meta": {
"executedQueryString": "from(bucket: \"Metrics\")\n |> range(start: 2024-04-28T14:23:34.925Z, stop: 2024-04-28T20:23:34.925Z)\n |> filter(fn: (r) => r[\"_measurement\"] == \"Electrical\")\n |> filter(fn: (r) => r[\"_field\"] == \"act_energy_pos\")\n |> aggregateWindow(every: 1h, fn: first, createEmpty: false)\n |> difference()"
"fields": [
"name": "Time",
"type": "time",
"typeInfo": {
"nullable": true
"type": "number",
"typeInfo": {
"frame": "float64",
"nullable": true
"labels": {}
"data": {
"values": [
1714320000000,
1714323600000,
1714327200000,
1714330800000,
1714334400000,
1714335814925
2167,
3472,
6036,
4345,
5182,
3564
"refId": "A"
