The merge of PR #115610 (https://github.com/grafana/grafana/pull/115610) to main initiates the process of decoupling plugin-related properties from GrafanaBootConfig. This change specifically targets config.apps and will be followed by the deprecation of config.panels and config.datasources in the ensuing months. The removal of config.apps from the @grafana/runtime package is projected to occur in Grafana 13.2 and PR #115610 is targeted for the 12.4 release of Grafana.
What changed
The config.apps property from the @grafana/runtime package is now marked as deprecated.
Why we made this change
This deprecation is necessary to facilitate the asynchronous loading of plugin-related metadata, ensuring they are initialized only when Grafana requires them.
Who is affected
- Affected: Plugins or core Grafana code that access
config.appsproperty from the@grafana/runtimepackage - Not Affected: Plugins or core Grafana code that don’t access
Action required (for plugin authors)
Replace all accesses to the config.apps property with one of the following public alternatives from the @grafana/runtime package:
For checking if an app plugin is installed (doesn’t check if the plugin is enabled):
- Function:
isAppPluginInstalled - Hook:
useAppPluginInstalled
For getting an app plugin’s version:
- Function:
getAppPluginVersion - Hook:
useAppPluginVersion
To address this, your plugin must target Grafana version 12.4 or newer. Alternatively, you can implement runtime checks as detailed in the guide available at https://grafana.com/developers/plugin-tools/how-to-guides/runtime-checks.
Action required (for Grafana core maintainers)
Replace all accesses to the config.apps property with one of the following internal alternatives from the @grafana/runtime package:
For getting meta data for a specific plugin:
- Function:
getAppPluginMeta - Hook:
useAppPluginMeta
For getting all meta data:
- Function:
getAppPluginMetas - Hook:
useAppPluginMetas
More resources
Track the overall progress of decoupling plugins from boot data in this Epic: https://github.com/grafana/grafana/issues/114889
For the progress related to config.apps within core Grafana, see the migrate away from config.apps Epic: https://github.com/grafana/grafana/issues/115617
