Define Relative Times in Dashboard Object
Hello Grafana Support,
We are trying to define the time_options in a scripted dashboard but it is ignoring the values we provide.
But refresh does works as intended in the below.
Before:
refresh_intervals: ["5s", "10s", "30s" , "1m", "5m", "15m", "30m", "1h", "2h", "1d" ],
time_options: ["5m", "15m", "1h", "6h", "12h", "24h", "2d", "7d", "30d"],
After:
refresh_intervals: ["5s", "10s", "30s"],
time_options: ["5m", "15m", "1h", "6h", "30d"],
  • v7.3.4
  • Define relative time ranges
  • Setting the timepicker in the dashboard object
What happened?
  • The provided values were ignored
  • We expected the timepicker to show the values we defined properly
  • The dashboard object we provided:
timepicker: {
    collapse: false,
    enable: true,
    notice: false,
    now: true,
    status: "Stable",
    type: "timepicker",
Did you receive any errors in the Grafana UI or in related logs?
  • No
