Dashboard time range overrides the relative time in the query options
Hi there,
this is my first post in the community. I have setup a dashboard with various weather values and corona values, as well as gas prices and so one.
For some of them I have define a relative time in the query options of the panel. The dashboard has a refresh rate of 5 min and a time range of “This year so far”.
Now it happens that the time rage of the dashboard overrides the relative time in the query options. I noticed that after the refresh the correct values are displayed of max. 2 min and then out of the sudden, those panels having a relative time are just displaying the values of the time range of the dashboard instead the other once.
What I’m doing wrong?
I’m running the latest stable grafana version in a docker container.
Thanks Martin
welcome to the :grafana: community @devmafi!
Can you export and share the dashboard json for the dashboard when it’s using the panel time override and again when it’s reverted to the relative time for all of the panels?
If you’re also able to include screenshots they can really help the community to visualize what you’re seeing versus what you expect to see.
Hi, I have the very same problem. I set up a dashboard with a time range of 24h and a single panel with a relative time of 1h. The panel with 1h reverts to 24h for a few seconds every 45 seconds. Interval is set to 5s.
This is the json for the dashboard with relative time set:
“annotations”: {
“list”: [
“builtIn”: 1,
“datasource”: {
“type”: “grafana”,
“uid”: “-- Grafana --”
“enable”: true,
“hide”: true,
“iconColor”: “rgba(0, 211, 255, 1)”,
“name”: “Annotations & Alerts”,
“target”: {
“limit”: 100,
“matchAny”: false,
“tags”: ,
“type”: “dashboard”
“type”: “dashboard”
“editable”: true,
“fiscalYearStartMonth”: 0,
“graphTooltip”: 0,
“id”: 61,
“links”: ,
“liveNow”: true,
“panels”: [
“datasource”: {
“type”: “prometheus”,
“uid”: “XomoJ9fVk”
“description”: “”,
“fieldConfig”: {
“defaults”: {
“color”: {
“mode”: “palette-classic”
“custom”: {
“axisCenteredZero”: false,
“axisColorMode”: “text”,
“axisLabel”: “”,
“axisPlacement”: “auto”,
“barAlignment”: 0,
“drawStyle”: “line”,
“fillOpacity”: 100,
“gradientMode”: “none”,
“hideFrom”: {
“legend”: false,
“tooltip”: false,
“viz”: false
“lineInterpolation”: “smooth”,
“lineWidth”: 2,
“pointSize”: 5,
“scaleDistribution”: {
“type”: “linear”
“showPoints”: “never”,
“spanNulls”: false,
“stacking”: {
“group”: “A”,
“mode”: “normal”
“thresholdsStyle”: {
“mode”: “off”
“mappings”: ,
“thresholds”: {
“mode”: “absolute”,
“steps”: [
“color”: “green”,
“value”: null
“color”: “red”,
“value”: 80
“unit”: “short”
“overrides”:
“gridPos”: {
“h”: 11,
“w”: 24,
“x”: 0,
“y”: 0
“hideTimeOverride”: false,
“id”: 2,
“interval”: “5s”,
“options”: {
“legend”: {
“calcs”: [
“max”
“displayMode”: “table”,
“placement”: “right”,
“showLegend”: true,
“sortBy”: “Max”,
“sortDesc”: true
“tooltip”: {
“mode”: “multi”,
“sort”: “desc”
“pluginVersion”: “9.4.7”,
“targets”: [
“datasource”: {
“uid”: “XomoJ9fVk”
“editorMode”: “builder”,
“exemplar”: false,
“expr”: “haproxy_frontend_current_sessions{proxy=~"AG1-FE|AG2-FE|AG3-FE|AG4-FE|AG4B-FE|AG5-FE|AG6-FE|AG7-FE|DRUPAL"}”,
“format”: “time_series”,
“instant”: false,
“interval”: “5”,
“legendFormat”: “{{proxy}}”,
“range”: true,
“refId”: “A”
“timeFrom”: “1h”,
“title”: “Sessioni ultima ora”,
“type”: “timeseries”
“datasource”: {
“uid”: “XomoJ9fVk”
“description”: “”,
“fieldConfig”: {
“defaults”: {
“color”: {
“fixedColor”: “green”,
“mode”: “thresholds”
“decimals”: 0,
“mappings”: [
“options”: {
“0”: {
“index”: 0,
“text”: “-”
“type”: “value”
“max”: 200,
“min”: 0,
“noValue”: “–”,
“thresholds”: {
“mode”: “absolute”,
“steps”: [
“color”: “green”,
“value”: null
“color”: “#EAB839”,
“value”: 100
“color”: “red”,
“value”: 200
“unit”: “short”
“overrides”: [
“matcher”: {
“id”: “byName”,
“options”: “[totale]”
“properties”: [
“id”: “max”,
“value”: 1000
“id”: “color”,
“value”: {
“mode”: “fixed”
“gridPos”: {
“h”: 12,
“w”: 12,
“x”: 0,
“y”: 11
“id”: 3,
“interval”: “5s”,
“options”: {
“colorMode”: “background”,
“graphMode”: “area”,
“justifyMode”: “auto”,
“orientation”: “auto”,
“reduceOptions”: {
“calcs”: [
“lastNotNull”
“fields”: “”,
“values”: false
“text”: {
“titleSize”: 30,
“valueSize”: 80
“textMode”: “value_and_name”
“targets”: [
“datasource”: {
“uid”: “XomoJ9fVk”
“editorMode”: “code”,
“exemplar”: false,
“instant”: true,
“interval”: “”,
“range”: false,
“refId”: “A”
“title”: “Sessioni correnti”,
“transformations”: [
“id”: “calculateField”,
“options”: {
“alias”: “[totale]”,
“mode”: “reduceRow”,
“reduce”: {
“reducer”: “sum”
“type”: “stat”
“datasource”: {
“uid”: “XomoJ9fVk”
“description”: “”,
“fieldConfig”: {
“defaults”: {
“custom”: {
“hideFrom”: {
“legend”: false,
“tooltip”: false,
“viz”: false
“type”: “linear”
“overrides”:
“gridPos”: {
“h”: 12,
“w”: 12,
“x”: 12,
“y”: 11
“id”: 5,
“interval”: “5s”,
“options”: {
“calculate”: false,
“cellGap”: 4,
“cellValues”: {
“decimals”: 0,
“unit”: “binBps”
“color”: {
“exponent”: 0.5,
“fill”: “blue”,
“max”: 20971598,
“min”: 0,
“mode”: “scheme”,
“reverse”: false,
“scale”: “exponential”,
“scheme”: “Spectral”,
“steps”: 64
“exemplars”: {
“color”: “rgba(255,0,255,0.7)”
“filterValues”: {
“le”: 2048
“legend”: {
“show”: true
“rowsFrame”: {
“layout”: “unknown”
“tooltip”: {
“show”: true,
“yHistogram”: false
“yAxis”: {
“axisPlacement”: “left”,
“decimals”: 0,
“reverse”: false
“targets”: [
“datasource”: {
“uid”: “XomoJ9fVk”
“expr”: “rate(haproxy_frontend_bytes_out_total{proxy=~"AG1-FE|AG2-FE|AG3-FE|AG4-FE|AG4B-FE|AG5-FE|AG6-FE|AG7-FE|DRUPAL"}[$__rate_interval])”,
“range”: true,
“refId”: “A”
“title”: “Traffico ultime 24 ore”,
“type”: “heatmap”
“refresh”: “5s”,
“revision”: 1,
“schemaVersion”: 38,
“style”: “dark”,
“tags”: ,
“templating”: {
“list”:
“time”: {
“from”: “now-24h”,
“to”: “now”
“timepicker”: {
“hidden”: false
“timezone”: “”,
“title”: “HAProxy DMZ”,
“uid”: “80iRbrf4z”,
“version”: 35,
“weekStart”: “”
This is the json for the dashboard without the relative time set:
“annotations”: {
“list”: [
“builtIn”: 1,
“datasource”: {
“type”: “grafana”,
“enable”: true,
“hide”: true,
“target”: {
“limit”: 100,
“matchAny”: false,
“tags”: ,
“type”: “dashboard”
“type”: “dashboard”
“editable”: true,
“graphTooltip”: 0,
“id”: 61,
“links”: ,
“liveNow”: true,
“panels”: [
“datasource”: {
“uid”: “XomoJ9fVk”
“description”: “”,
“fieldConfig”: {
“defaults”: {
“color”: {
“custom”: {
“axisLabel”: “”,
“barAlignment”: 0,
“fillOpacity”: 100,
“hideFrom”: {
“legend”: false,
“tooltip”: false,
“viz”: false
“lineWidth”: 2,
“pointSize”: 5,
“type”: “linear”
“spanNulls”: false,
“stacking”: {
“group”: “A”,
“mode”: “normal”
“mode”: “off”
“mappings”: ,
“thresholds”: {
“mode”: “absolute”,
“steps”: [
“color”: “green”,
“value”: null
“color”: “red”,
“value”: 80
“unit”: “short”
“overrides”:
“gridPos”: {
“h”: 11,
“w”: 24,
“x”: 0,
“y”: 0
“id”: 2,
“interval”: “5s”,
“options”: {
“legend”: {
“calcs”: [
“max”
“showLegend”: true,
“sortBy”: “Max”,
“sortDesc”: true
“tooltip”: {
“mode”: “multi”,
“sort”: “desc”
“targets”: [
“datasource”: {
“uid”: “XomoJ9fVk”
“exemplar”: false,
“instant”: false,
“interval”: “5”,
“range”: true,
“refId”: “A”
“datasource”: {
“uid”: “XomoJ9fVk”
“description”: “”,
“fieldConfig”: {
“defaults”: {
“color”: {
“decimals”: 0,
“mappings”: [
“options”: {
“0”: {
“index”: 0,
“text”: “-”
“type”: “value”
“max”: 200,
“min”: 0,
“noValue”: “–”,
“thresholds”: {
“mode”: “absolute”,
“steps”: [
“color”: “green”,
“value”: null
“color”: “#EAB839”,
“value”: 100
“color”: “red”,
“value”: 200
“unit”: “short”
“overrides”: [
“matcher”: {
“id”: “byName”,
“properties”: [
“id”: “max”,
“value”: 1000
“id”: “color”,
“value”: {
“mode”: “fixed”
“gridPos”: {
“h”: 12,
“w”: 12,
“x”: 0,
“y”: 11
“id”: 3,
“interval”: “5s”,
“options”: {
“reduceOptions”: {
“calcs”: [
“lastNotNull”
“fields”: “”,
“values”: false
“text”: {
“titleSize”: 30,
“valueSize”: 80
“targets”: [
“datasource”: {
“uid”: “XomoJ9fVk”
“exemplar”: false,
“instant”: true,
“interval”: “”,
“range”: false,
“refId”: “A”
“options”: {
“reduce”: {
“reducer”: “sum”
“type”: “stat”
“datasource”: {
“uid”: “XomoJ9fVk”
“description”: “”,
“fieldConfig”: {
“defaults”: {
“custom”: {
“hideFrom”: {
“legend”: false,
“tooltip”: false,
“viz”: false
“type”: “linear”
“overrides”:
“gridPos”: {
“h”: 12,
“w”: 12,
“x”: 12,
“y”: 11
“id”: 5,
“interval”: “5s”,
“options”: {
“calculate”: false,
“cellGap”: 4,
“cellValues”: {
“decimals”: 0,
“unit”: “binBps”
“color”: {
“exponent”: 0.5,
“fill”: “blue”,
“max”: 20971598,
“min”: 0,
“mode”: “scheme”,
“reverse”: false,
“steps”: 64
“exemplars”: {
“filterValues”: {
“le”: 2048
“legend”: {
“show”: true
“rowsFrame”: {
“layout”: “unknown”
“tooltip”: {
“show”: true,
“yHistogram”: false
“yAxis”: {
“decimals”: 0,
“reverse”: false
“targets”: [
“datasource”: {
“uid”: “XomoJ9fVk”
“range”: true,
“refId”: “A”
“type”: “heatmap”
“refresh”: “5s”,
“revision”: 1,
“style”: “dark”,
“tags”: ,
“templating”: {
“list”:
“time”: {
“from”: “now-24h”,
“to”: “now”
“timepicker”: {
“hidden”: false
“timezone”: “”,
“uid”: “80iRbrf4z”,
“version”: 35,
“weekStart”: “”
I’m using Grafana 9.4.7.
Can you help me?
Thanks,
Giovanni
I am facing the same problem. Sounds like a bug in Grafana to me. Is there already an issue for this on Github?
I also have this problem. I have a 1yr time range as the dashboard default, but want to have only 7days or 1month for some panels.
