Hi there, im a bit confused that it is not working. tried 0 and 2 and auto , but it gets me bad values
Which version of Grafana are you on?
Grafana
Current version: 5.3.4
It is set up in docker as a Homeassistant addon
Graph panel should update correctly after you click Apply. If not, it might be a bug in an older version. I’m on version 7.1.5 and I don’t have this issue.
i wasmistaken ver 5 is integration version
grafana is GRAFANA=“7.3.1” up to date tho
