I am using Grafana 8 / linux (the latest docker image)
In a time series panel with two data series, I am trying to specify a different style for the second series by specifying overrides for the 2nd. However, these seem not to be effective.
Here is a screenshot of the graph:
Here are the settings I am trying to apply to one of the series:
Retrieving the data for the two series from InfluxDB2 does work (the values change are correct). However, somehow the override does not.
What I would expect is the 2nd series to be shown in yellow, and with the “stair case” interpolation. However, the overrides seem not to be applied.
I think it is somehow related to the selector for the override rule. When I chose the last option (which is “value (base field name)”, then the rules are applied, but in this case to both data series.
