Hello
I would like to now why my bar chart display an error in order of dates :
As you can see, Saturday and sunday are between monday and thursday of this month.
It can also be used for other days and dates.
I give you the json configuration :
"datasource": {
"type": "influxdb",
"uid": "b383168e-2097-4f5b-a983-0d137adfb3aa"
"fieldConfig": {
"defaults": {
"custom": {
"lineWidth": 1,
"fillOpacity": 80,
"gradientMode": "none",
"axisPlacement": "auto",
"axisLabel": "",
"axisColorMode": "text",
"axisBorderShow": false,
"scaleDistribution": {
"type": "linear"
"axisCenteredZero": false,
"hideFrom": {
"tooltip": false,
"viz": false,
"legend": false
"thresholdsStyle": {
"mode": "line"
"color": {
"mode": "palette-classic"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "text",
"value": null
"overrides": [
"matcher": {
"id": "byFrameRefID",
"options": "B"
"properties": [
"id": "unit",
"value": "kwatth"
"matcher": {
"options": "D"
"properties": [
"id": "displayName",
"value": "IPE"
"id": "unit",
"value": "Wh/m²/°C"
"id": "color",
"value": {
"fixedColor": "dark-green",
"mode": "fixed"
"gridPos": {
"h": 8,
"w": 11,
"x": 9,
"y": 34
"id": 50,
"targets": [
"datasource": {
"type": "influxdb",
"hide": true,
"query": "import \"timezone\"\r\n\r\noption location = timezone.location(name: \"Europe/Paris\")\r\n\r\nfrom(bucket: \"GIN\")\r\n |> range(start: v.timeRangeStart, stop: v.timeRangeStop)\r\n |> filter(fn: (r) => r[\"_measurement\"] == \"Consommation\")\r\n |> filter(fn: (r) => r[\"_field\"] == \"Chauffage_chambre1\" or r[\"_field\"] == \"Chauffage_chambre2\" or r[\"_field\"] == \"Chauffage_cuisine\" or r[\"_field\"] == \"Chauffage_entree\" or r[\"_field\"] == \"Chauffage_salledebain\")\r\n |> difference(nonNegative: true, initialZero: true, columns: [\"_value\"])\r\n |> filter(fn: (r) => r[\"_value\"] > 0.01)\r\n |> aggregateWindow(every: ${Lisser}, fn: sum, createEmpty: false, offset: -1s)\r\n |> pivot(rowKey:[\"_time\"], columnKey: [\"_field\"], valueColumn: \"_value\")\r\n |> map(fn: (r) => ({\r\n r with\r\n total_chauffage: \r\n (if exists r.Chauffage_chambre1 then r.Chauffage_chambre1 else 0.0) +\r\n (if exists r.Chauffage_chambre2 then r.Chauffage_chambre2 else 0.0) +\r\n (if exists r.Chauffage_cuisine then r.Chauffage_cuisine else 0.0) +\r\n (if exists r.Chauffage_entree then r.Chauffage_entree else 0.0) +\r\n (if exists r.Chauffage_salledebain then r.Chauffage_salledebain else 0.0)\r\n }))\r\n |> keep(columns: [\"_time\", \"total_chauffage\"])\r\n",
"refId": "A"
"datasource": {
"type": "influxdb",
"hide": true,
"query": "import \"timezone\"\r\n\r\noption location = timezone.location(name: \"Europe/Paris\")\r\n\r\n// Requête pour les autres champs de chauffage\r\nchauffage_others = from(bucket: \"GIN\")\r\n |> range(start: v.timeRangeStart, stop: v.timeRangeStop)\r\n |> filter(fn: (r) => r[\"_measurement\"] == \"Consommation\")\r\n |> filter(fn: (r) => r[\"_field\"] == \"Chauffage_chambre1\" or r[\"_field\"] == \"Chauffage_chambre2\" or r[\"_field\"] == \"Chauffage_cuisine\" or r[\"_field\"] == \"Chauffage_entree\" or r[\"_field\"] == \"Chauffage_salledebain\")\r\n |> difference(nonNegative: true, initialZero: true, columns: [\"_value\"])\r\n |> filter(fn: (r) => r[\"_value\"] > 0.01)\r\n |> aggregateWindow(every: ${Lisser}, fn: sum, createEmpty: false, offset: -1s)\r\n\r\n// Requête pour Chauffage_salon avec conversion en kWh\r\nchauffage_salon = from(bucket: \"GIN\")\r\n |> range(start: v.timeRangeStart, stop: v.timeRangeStop)\r\n |> filter(fn: (r) => r[\"_measurement\"] == \"Consommation\" and r[\"_field\"] == \"Chauffage_salon\")\r\n |> difference(nonNegative: true, initialZero: false, columns: [\"_value\"])\r\n |> filter(fn: (r) => r[\"_value\"] > 0.01)\r\n |> aggregateWindow(every: ${Lisser}, fn: sum, createEmpty: false, offset: -1s)\r\n |> map(fn: (r) => ({ r with _value: r._value * 0.001 })) // Conversion en kWh\r\n\r\n// Union des deux requêtes\r\nunion(tables: [chauffage_others, chauffage_salon])\r\n |> pivot(rowKey:[\"_time\"], columnKey: [\"_field\"], valueColumn: \"_value\")\r\n |> map(fn: (r) => ({\r\n r with\r\n total_chauffage: \r\n (if exists r.Chauffage_chambre1 then r.Chauffage_chambre1 else 0.0) +\r\n (if exists r.Chauffage_chambre2 then r.Chauffage_chambre2 else 0.0) +\r\n (if exists r.Chauffage_cuisine then r.Chauffage_cuisine else 0.0) +\r\n (if exists r.Chauffage_entree then r.Chauffage_entree else 0.0) +\r\n (if exists r.Chauffage_salledebain then r.Chauffage_salledebain else 0.0) +\r\n (if exists r.Chauffage_salon then r.Chauffage_salon else 0.0)\r\n }))\r\n |> keep(columns: [\"_time\", \"total_chauffage\"])\r\n",
"refId": "B"
"datasource": {
"type": "influxdb",
"hide": true,
"query": "import \"timezone\"\r\n\r\noption location = timezone.location(name: \"Europe/Paris\")\r\n\r\nfrom(bucket: \"GIN\")\r\n |> range(start: v.timeRangeStart, stop: v.timeRangeStop)\r\n |> filter(fn: (r) => r[\"_measurement\"] == \"Meteo\")\r\n |> filter(fn: (r) => r[\"_field\"] == \"DJC\")\r\n |> aggregateWindow(every: ${Lisser}, fn: sum, createEmpty: false, offset: -1s)",
"refId": "C"
"datasource": {
"name": "Expression",
"type": "__expr__",
"uid": "__expr__"
"expression": "$B*1000/80/$C",
"hide": false,
"refId": "D",
"type": "math"
"datasource": {
"type": "__expr__",
"uid": "__expr__"
"hide": false,
"refId": "E",
"type": "math"
"title": "IPE",
"transformations": [
"id": "configFromData",
"options": {
"configRefId": "E",
"mappings": [
"fieldName": "E",
"handlerKey": "threshold1",
"reducerId": "mean"
"fieldName": "Time",
"reducerId": "mean"
"id": "formatTime",
"options": {
"timeField": "Time",
"outputFormat": "ddd DD MMM",
"useTimezone": true,
"timezone": ""
"type": "barchart",
"options": {
"orientation": "auto",
"xTickLabelRotation": 0,
"xTickLabelSpacing": 100,
"showValue": "auto",
"stacking": "none",
"groupWidth": 0.7,
"barWidth": 0.97,
"barRadius": 0,
"fullHighlight": false,
"tooltip": {
"mode": "single",
"sort": "none"
"legend": {
"showLegend": true,
"displayMode": "list",
"placement": "bottom",
"calcs": []
The “format time” transformation changes nothing
the problem does not appear on a “time series”
Thanks for your help
