Datasource mismatch between Alert Rule and Screenshot
grafana: v11.6.1
image renderer: v3.12.6
    I want to ensure that when an alert fires, the screenshot is generated using the specific datasource defined in that alert rule’s conditions.
    I’m using Grafana’s alerting feature with screenshots enabled via the following configuration:
unified_alerting.screenshots:
  capture: true
  upload_external_image_storage: true
and add Alert Rules with specific datasource.
It linked a dashboard panel.
  • What happened?
    When an alert rule enters the firing state, a screenshot is automatically generated as expected. However, the datasource used to generate this screenshot is not the one specified in the alert rule itself. Instead, it seems to be using a different datasource from the dashboard’s variables.
Is there a way to resolve this issue?
    I suspect it’s using either the default value for the var-datasource or the most recently saved one.
