When setting a query / alert condition in Grafana, how can I make it so the alert rule defaults to the default data source of the environment?
My workflow:
- create alert rule on Grafana
- export it using the alert provisioning API
- use alert in new environment
Unfortunately, the datasourceUid is then set to the environment where the alert rule was created; is it possible to change it so that the alert rule uses the default data source whatever environment it is provisioned in?
