I’ve a dashboard generated by json script but when i try to access via a external access my html part is configured to launch a php script on my local server.
When i’m in my local Network it’s ok but from a external device it’s not possible to acces in my private NAT/DHCP network.
How i can do to use grafana as proxy ?
a example of my http url which exectue php script on a remote server :
This seems a litte out of scope of Grafana. But as a first step you need to solve the external access to X.X.X.X, may it be thru exposing the private IP or running a nginx server or similar in front. As soon as you solved this you should be able to expose the content on X.X.X.X in an iframe in Grafana.
Yes i expected to this, ok now i’m working to get the IP’s client and add a condition to match with the good URL in my href in the JavaScript, Maybe you’ve a idea ?
User access to the dashboard in my Private VLAN, and sometimes Remote acces as a NAT/DHCP acces remote so when my user use the frame i’ve a module which contain a URL with Private IP,…doesn’t work remote user
