Hi There,
I am evaluating Grafana and I am enjoying it so far. I have hooked up the Azure monitor Datasource to look at monitoring a network connection. The data is a datarate in bits/second. I want to add a panel to show the data usage (not rate) of the last 30 days. I want to be able to convert the bits/s into bits so the data calculation is correct.
Is there any way to do this?
Cheers
