9.3.1 (docker.io/grafana/grafana:9.3.1), data source is Graphite, fed through StatsD. -
Turning a continuous stream of smart meter readings (total consumption, monotonic gauge) into a bar graph (or line graph) with hourly consumption. -
Create a graph, based on a metric (saystats.gauges.smarthome.utilities-power-high) and then I get stuck, because I’m trying to find a function to aggregate a delta per time window (an hour, a day, whatever makes sense for the current timeframe).
I’m convinced what I’m trying to do should be possible, right? It feels like a fairly common usecase, but maybe I’m mistaken.
Any help would be appreciated, thanks in advance!
