Data shows in Chronograf but not Grafana
I have seen several recent and near identical posts(with no solution) to mine here as well as on reddit. I was hopping to almost bump this as so to speak. I am a novice linux guy and got Chronograf to work with Influx and Telegraf. When I try to add the same working Influx DB to Grafana I get no data. They were all the newest versions and downloaded per directions on their respective sites. Influx, Grafana and Chronograf are all on the same host.
I am using the same DB username, ports and passwords between the two programs.
Influx data shows up just fine in chronograf https://imgur.com/w8tQNDI
The connection is the same for Grafana https://imgur.com/k0wMRrO
I tried it with and without “basic auth.” https://imgur.com/7SxBw8n
But I get no data in grafana https://imgur.com/CUP4Pmm
Query inspector https://imgur.com/OLbVISJ
Do you have any thoughts or suggestions?
Influx https://gist.github.com/zmanguy/be4b07116d0c9678e3f378b00b28a92f
Grafana https://gist.github.com/zmanguy/46406a55cf1352a96be0a31917f70ff2
Please post any ideas or thoughts. What are you thinking? Thank you for your time and help!
The query in the query editor and the query in the query inspector are different. Is your measurement really called “measurement” like in the screenshot for the query inspector?
  • Do the dropdowns work? Can you choose different measurements?
  • Are the raw queries in Chronograf the same as the ones in Grafana?
You should be able to copy the query from Chronograf into Grafana (use toggle edit mode in the query editor to get raw mode) and then replace :interval: with time($__interval):
It wasn’t! Thank you thank you thank you!! You helped me figure it out. I appreciate it more than you know!
